As many of you know I purchased Dell’s LT earlier this week. I went down to the DMV to get clear title, and they issued new plates.
Tonight, I went to remove the old plate, but found the top of the license plate frame secured with two unique bolts. The bolts are round top, with a 6-sided hole and a pin in the middle. They appear to be a security measure against theft. Which was kind of pointless since I was able to remove the whole license plate frame section of the bike by taking out the two torx screws on the top of the assemble. These two security screws/bolt are fastened with 10mm nut from the inside. Of course when I try to unscrew the nut the bolts spin as well.
Does anyone know if the tool to remove these bolts is available in a hardware store? Or are they unique to the manufacturer of the plate frame?
