jzeiler said:
There is little low end torque on the LT. Don't exceed 1,600 rpm as you release the clutch until it is fully engaged. Stay in first until 4,500 and see how that feels. You can go all the way to 62 mph in 1st before you hit the rev limiter. Normal shifts should always be at 3,500 or above. Learn to use the power band above 4,500.
+1
I drive it like I stole it, and shift around 5500K. She sure is fun in that range... During start off though, you are not likely to get her front wheel off the ground, if that's what you are thinking...
Welcome! Enjoy the big girl! This site has an unbelievable amount of information to make owning the K12 an absolute pleasure. Here is a post by JSpen that sums up lots of great info...
Originally Posted by JPSpen
Everyone has given you the straight info....
I'll give you the lecture...
When coming to a stop.. Leave the engine running and in first gear always...
Turn off the engine by putting the side stand down... Hold the bike upright for 20-30 seconds to let the oil drain out from the back side of the cylinders..
Then put it on the side or center stand....
One of these days you'll forget and get a 5 minute smoke trail... It's normal...
Don't come to a stop with the front end turned EVER...Because of the telelever front end.. Any energy that would have been used up by bobbing the front end on a conventional bike will cause the bike to want to jump towards the ground....
If she starts over. Once it get's past the point of no return... You're not going to stop it...
Don't try.. You'll only get hurt... She has bumpers and as long as you don't hit the windshield on something like a wall or another car or bike.. . She'll survive..
The engines are kind of noisy and the alternator drive can make some noise if you've got a big load on the electrical system....
42psi front, 48psi Rear...Religiously unless you like to buy tires..
The tires will start cupping and you'll start hearing a roar when you lean the bike...NORMAL....
Finally the roar will get so bad that you'll have to buy new tires to make it go away..NORMAL...
It really concerns me that you don't have a license.. An LT is NOT a good first bike...Hopefully you'll survive long enough to learn to ride it...
Oh yeah, You've got an LT now.. NOTHING will EVER be CHEAP again...
Everything you buy for her will be twice as much as you thought it would be.. At least..
Don't cheap out on anything... It never pays on this bike..
Have fun...
