Hi all, does anyone have some illustrations of how to remove the side panels on a 2004 LT. Which and how many screws? Do the J-pegs have to come off etc. Any help would be appreciated.
best thing to do if you dont have a manual is either get a clymer (if you plan on doing work yourself ) or download a cheapo version off somewhere like ebay.
You can start by taking off your tip over wings 2 screws underneath
silver section 3 screws
3 screws at tabs
turn signal 1 screw ( 2 inside on the panel)
3 screws on your wind deflector ( 1 inside on panel)
3 on tank cover( you have to remove the entire u shape piece)
one under the seat
pull the tab through the rubber grommet on the side of the bike and lift the side panel off.
As I dont have jpegs you are on your own there unless someone tells you how to get them loose.
Print one of these out and keep it with the bike,
you won't need it after you've done it a few times.
Thanks for the illistrations. they will be very helpful. If I ever get time to play.
