I actually had two issues. One that John "Eagle eyes" Zeiler saw on a picture (over set rivet on the disk) and then the apparent out of perpendicular machining of one or both contact surfaces. I may never know for sure as I have no plans to tear down the bike to inspect the parts.
:grin:
Now that I've gotten used to making harder launches, my shudder problem is barely detectable. I only notice it when trying to inch ahead in the garage. If I lightly engage the clutch at idle RPM, then it will shudder. If I rev to 1500-1800 before engaging the clutch and let it engage reasonably quickly, things are quite smooth. That just isn't my norm for driving a standard shift vehicle so I have to remember to do that.
My norm is to engage the clutch to the friction point and then simultaneously add in throttle and clutch so as to maintain the RPM just slightly above idle (1200 on the LT) until the clutch is engaged fully. On my LT, I now do much the opposite. I rev to 1500+ RPM and then engage the clutch while holding nearly constant throttle. For a normal start on the level, that allows the RPM to sag back to 1200 or so at the full engagement point so as to not heat the clutch excessively. This pretty much completely avoids the shudder, at least the audible part. I can still feel some variation as the clutch engages, but someone else probably wouldn't notice. I know it is there, so I notice the slight variation during engagement. I can then motor away with throttle. Easier to do than describe.
