+1kellenbenz said:Everything is normal...the brake light flashes during the test until it senses wheel movement. As long as the light goes out after you start to roll everything is fine.
The LT is not canbus also.
Ron
Ron
I guess the one that wants you to know that your ABS system is functioning properly, and has run through a system self check every time before you ride.Drakba said:What bonehead engineer in Germany thought it would be a good idea to flash Brake Failure, until you started to move a bike? Eeesh.....
Many thanks for the sanity.....
Paul
