History: 2002 K1200LT
Bike did not start this spring.
Bike did start last summer but I did not ride it much because I was working allot and the bike needed new tires. I stored it for the winter with not much gas in it and no fuel stabilizer.
Bike does have a new battery.
I don’t have a local BMW dealer and I don’t have a trailer to tow bike.
What I have done so far:
Per my previous post on this site someone suggested to jumper across fuel pump terminals with a battery charger. I took bike apart and did this and I could hear pump running.
When I put bike back together it would not start but did sputter when using starter fluid.
I checked fuse for fuel pump and it was ok.
I took gas tank off again and pulled fuel pump and hooked it back up out of the fuel tank and got nothing. I jumpered across fuel pump terminals with a screw driver and got no spark.
Not sure how much of the wiring needs to be hooked up so bike will run but pretty sure I had everything hooked up. The last time I know I did not have the tank on so there is a plug on the top of the tank near gas tap that was not connected.
Seems to me I might have an electrical problem to the fuel pump.
Thanks for any help getting bike started.
Scott G
Scott G
