As some of you may be aware I have to change my gearbox and I was not looking forward to rolling around the garage floor so decided to invest in a bike lift. I do not really have the space for the table type lifts and the Big Blue had caught my eye. A couple of emails to the manufacturers to clear up a few details and it was on it's way and arrived the next day. Dave then called me to explain how the specific mounts for the K1200lt worked. Excellent service.
The lift is shipped as 3 main components in 2 large cardboard boxes. It took me about half an hour to assemble the lift and the fit and finish is first class.
The K1200LT mounting kit is an adaptation of the foot peg mounting kit (http://on-bike.com/mounts_options.htm) and has uprights that locate into the 16 mm hole in the frame above the passenger footrests - the holes that you would use to undo the long bolt that secures the gearbox to the frame. David sent 2 front mounts (they are actually Multi-mounts) as they place the bike at different angles on the lift. The person that had helped David develop the lift preferred the taller of the 2 and I soon found out why. The lower and wider of the 2 mounts will cover part of the oil filter cover and the tip over wing will interfere with the lift support arm. I imagine that the taller slimmer mount will avoid these issues but have not tried it yet. If you use this mount you have to remove or bend back the tabs or you could fill the void with a piece of wood.
Getting the bike attached to the lift was very easy. Firstly offer up the rear mount and get it centred. Secure the side that will be nearest the lift and mark the position of the outside leg. Slide the assembly on to the lifting arm and secure. Place the bike on the sidestand where you want it lifted from and slide the lift in towars the bike. Adjust the height of the lifting arm so that the peg lines up with the hole. Now stand the bike upright and move the bike backwards or forwards as required. Push or pull the lift the last couple of inches until the peg is fully home and then fit the other upright. The bike is fairly stable in this position so there is no panic to fit the upright.
Check the bike is square on the lift and the front mount is in the right position and you are ready to lift the bike. Once the bike is off the ground the bike is not rock solid - there is a bit of movement but once the slack is taken up I have no qualms about applying a lot of pressure to any stubborn nuts though it is advisable to loosen any fittings that you know will be stuborn before lifting (swing arm bolts?).
Overall I am very happy with the lift and here are a couple of photos.
