Wooohoooooo....rescued Beryl Beemer as from last Friday..............(big grin)
Grroooaannnn ...paid for the ICU treatment for the last 5 weeks......(no grin)
$2,263 for a new exhaust valve?????????????????????????????????????
BMW surgeons took note of the valve clearances before operating...
Inlet (.15-.20mm): .18 .18 .16 .16 .20 .18 .18 .16
Exhaust (.25-.30mm): .28 .28 .25 .25 .25 .28 .25 .28
Hmmmmm ok all valves are within specified limits...
ok ...I take some littery license here........bear with me here, the wound is still painful.
Anyone remember those "wide eyed" encounters that some motorcycle riders experience when they realise they have overcooked a corner or similar....well that was the same "wide eyed" feeling I got when initially presented with Beryl's "medical" bill.
"$2,263????......huh" (or something along those lines)......(I knew taking that defibrillator course would prove useful....
ZZZZZAAAAAaaaaaaapppppppppppp!!!!!!!!!!!!
Beryl has 129,594kms on the clock,....so the theatre staff in their combined wisdom thought they would carry out some extra elective surgery whilst the patient's head was removed.
The list is as:
1 11121464823 Gasket $53:41
4 11627662083 Gasket $10:00
1 11311461380 OAR Rail $26:99
1 11311465011 OAR Guide R $27:17
1 11311465189 OAR Keine U $24:20
1 11311465121 Bush $2.51
1 11311465013 Timing chain $104:61
1 11341465240 OAR valve $86:38
1 11121465139 Gasket $87:08
16 11341340849 Gasket ring $115:84
1 11002300053 Rep kit $34:30
3.5l 16406 Mineral oil $23:87
3.1 16820 workshop coolant $26:78
$545:45
Labour at 10 hours $880:00
Head refurbishment/preassembly $623:06
10% Goods Service tax $205:76
I hadn't asked for this extra surgery as such BUT....I spose if they had bothered to consult me that it would be a good thing to replace the timing chain and guides at this particular operation I would have "consented" anyway.....
All in all I accept that the "surgeons" have done their best for the patient and I can not really fault that....(what if I had had the timing chain replaced 1000kms ago??? ....what if I had done an oil change 1000kms ago???)..then it would have been a bit different, as it was I was gonna do an oil change at 130,000kms...so that was covered, plus the coolant needed doing also.....
One thing they have cured is at start up Beryl would "race" away to 2000rpm then taper back to 1000rpm....now she starts pretty much at 1000rpm. any ideas???
Another thing I found interesting is that the machine shop doing the head were able to reground all the valves, then adjust the valve stem length in order to reuse all the factory original shims....sooooo no shims to buy at $35 odd each (price from another BMW dealer sometime back)....the head was returned to the operating room all preassembled........good stuff huh?
The initial vapour trail is still there but that's Beryl....
Heyyyyy Coni, how are your problems being sorted....do you expect a patient medical bill at all or will yours be paid for by the BMW health fund??
(who was the K12 pilot on the anthracite coloured K12 I waved at yesterday in the Blue Mountains???)
cheers
Phill
'78 XS1100E "The tardis"
'99 K1200LT "Beryl Beemer"
The list is as:
$545:45
cheers
Phill
