Hi
I just put my bike away for the winter and I did the same routine that I did for my other bikes
1. change oil
2 stablize gas
3. remove battery.... because of where I store the bike I take the battery right out then charge it and store it at room temp until march
My question is with all the electronics on this bike (2011 rt ) will I have to restet anything other than the clock?
the manual says that the service schedule will be affected by leaving battery out and to check with the dealer???
Ps I was going to try to ride right through winter I can handle the cold but last Saturday when I went for a ride I nocticed that they already sanded the roads because of overnight ice. so I figured the heck with it I'll wait till March
The problem is:I don't have the option of leaving battery in the bike
so I still have the que. Does anyone know what effect leaving the battery out for 2 months will have? (ie adjusting maintenance sched etc)
This brings up another issue of storage temperature. I've never given it a second thought, but is there a lower temp limit tat would warrant removing the battery because of potential damage by low temp?
Theoretically heat kills batteries & conversely they deteriorate least and slowest when kept in cold storage - but only as long as they are not allowed to freeze.
IOW - Don't take it out of the bike unless you have to.
It probly will store some low voltage code, no big deal, it will be cleared at your next visit to your dealer. I bought my 05 RT back in may 2010, it sat for years without a battery in it, I brought it home, installed new battery and fired right up. I brought it to dealer for a recall update which involved hooking their computer up, mech said there were numerous low voltage codes he cleared, original owner tried starting with low battery many times during its 5 yrs in storage. All this did no harm to the bike, I put 4000 trouble free miles since.
After installing the battery you should do a TPS re-learn. Key on, don't start, rotate throttle stop to stop a couple times - it's in the manual.
If you have a GS911 it will prompt you to enter the correct date/time. After that you can reset the service reminder.
If you don't have a GS911 have the dealer do it for you.
The manual, 09, recommends removing the battery during long storage periods but that's up to you. I won't loose sleep either way or argue over it.
