1 - 3 of 3 Posts
only the tps that I am aware of make sure you remove the earth lead first and refit last and there will be a small spark when you disconnect and reconnect.
Reactions: Patric
TPS reset is it and you really don't NEED to do it as it will learn fairly quick on its own. But key on (no start), roll throttle open and closed a few times. Then key off. Now start and ride as normal.
Reactions: Patric
1 - 3 of 3 Posts
