Voyager- Mine is a 2003 with 16.5k miles. I hope to name it Lazurus because it hadn't been ridden for 10 years when I bought it about a month ago. I'm no Jesus and less of a mechanic but here is to hoping this thing can be brought back to life.
What torque setting did you use on the standard hex head banjo bolts? I decided I was into this project deep enough I popped for the $22 for a single bolt. Still hard to sit tonight. I figured it's like peeing in the ocean. I also ordered 5 on Amazon for $10 Just for the fun of it. They come with 10 crush washers which equals what BMW charges for each washer ($1) so the bolts are basically free. I think I may have stripped one on the front mc but it is holding. I'm going to test my torque wrench for accuracy tomorrow. Not sure why I would have stripped out two set for 18nm. I am going to begin using a recommendation by John Zeiler to start at 80% of recommended torque and move up by 10% if I have a leak.
To this point, I've changed the oil in the engine, final drive, transmission, changed the coolant, refilled the pre-load, changed fluid in clutch, replaced fuel pump/filter/hoses, replaced the fuel sensing unit, replaced gas lines and quick disconnects, cleaned the tank to the best of my ability, installed Spieglers, installed a new Odyssey Extreme PC680 battery, performed a cannisterectomy, bypassed the alarm, sent my injectors off to Mr. Injector (waiting for return), serviced the shift mechanism, removed the cd player and started on radioectomy tonight, . I think I need to pick up some fork oil and drain those, not showing any leakage but seemed like the thing to do while I've got the front wheel off. I'll probably pull the cover on the spark plugs to see what the wires look like (hoping they are ok with the low mileage). My tires should arrive tomorrow and I'll be trying my hand at installation and balancing.(I found a few bolts I haven't twisted off yet so what the hell!) I've got the Clymer manual and Kirk's videos have emboldened me to dive in. I haven't done anything this in-depth mechanically for about 50 years and then never have done much wrenching. I'm ready to replace the banjo bolt I stripped out and will hopefully get the brakes bled tomorrow and re-install the rear shock. Crossing my fingers the ABS isn't shot. I've got the integrated brakes. Then it will be time to fire this baby up and see if I did everything right. Then say 100 hail Mary's (I'm not even Catholic but figure it can't hurt) and try to get all the plastic, plugs, hoses etc back where it all belongs. Hope to be among the mobile majority soon. I made one major mistake by taking it to a local bike shop that had good social media reviews. They sat with it for 5 1/2 months and finally put it back together and gave it to me in worse condition by far than when I took it in. The bike looked like new when I bought it. Got a few scratches sitting in their shop. And I am pretty sure damaged the clear wings with brake fluid. I intend to ride it more than look at it so if it runs and rides like I hope it does it will be a small concession that can be dealt with later. I'll also tackle the weep hole once I know I have a running machine and not a pile of metal and plastic. In hindsight I should not have bought the bike but I've made larger bonehead decisions and hopefully this will turn out well. If not I'll have a parts bike, or sell it for one take it as another life lesson and move on. If I had regrets for all the stupid decisions I've made I'd have trouble living with myself. That's why we have wives right? I probably should have postponed some of the maintenance until I got it running but that's why I'm dumber than a motorcycle.
Thanks for the info on the torque question. Sorry for the novel but I figured I would save a lot of people suggesting I do that which is already done. I'm still open for additional opinions/suggestions and really appreciate the helpfulness and knowledge of this group. Looking forward to meeting many of you at future events.
Best regards
