roadcrave said:
Any one with pros-cons of this system and will it work with a k1200ltbaehr system, what is the wattage and distance in real use straight line and thru trees ect...also will it interface with other radios freq like Icom and midland, kenwood etc...matthew
I have the Capo II (together with Baehr K 1200 LT model) and my experience goes as follows:
* in my bike I had really bad alternator whine through the power feed to Capo II, I could not really use it at the beginning. Later Baehr came up with a filter (Raffy knows the model) which took care of the problem.
* I installed mine on top of the battery (see pic) and I relocated the Baehr intercom over the left saddlebag. This was because the channel selector of Capo is on top of the housing under a rubber grommet and you need access to that. Relocating the interom led to a problem of drivers cable becoming too short to it's designated installation place. Luckily the Capo came with one extra cable that I could use as extension.
* I have installed the antenna on top of the trunk (just in front of the luggage rack) However, in order to do this the antenna cable needs to be cut and you need a small coax connector for the antenna. This is also needed for the trunk removal.
* I was using my unit last summer during the CCR trip through Europe, Canada and US. My riding buddy had Icom. Our communication worked fine but really the signal reach on an open highway was not more than 300 - 400 meters. I don't know who was to blame. My Capo or my buddy's Icom. Probably the latter as his installation was very temporary. The unit just tucked between the rear seat and the saddlebag handle, antenna in horizontal position...
My overall opinion of the unit is that if you want a permanently installed clean unit this is OK. The channel selector system is clumsy, but how often you need to do it anyway. The price becomes rather high especially if you need the filter for the power cable to kill the alternator noise.
And ...as far I understand Baehr has already come up with a newer model but I'm not sure. I think Raffy knows and he can also tell are these "legal" to be sold in the US.
Regards
