1 - 11 of 11 Posts
I recently replaced the OEM exhaust on my 2003 LT with 60K with a Remus Street Can due to the fact that the OEM had a hole that had rusted thru. I also inserted the pipe in the end to cut down on the drone. When I ride the twisties I always stay in low gear with high RPMs to take advantage of engine braking. Now I get a lot of popping and an occasional backfire when doing that. I changed to premium grade fuel and was considering a RhineWest chip thinking that would solve my problems. After doing a bit of searching on the forum it appears that the RhineWest chip won't really cure my issue. I don't mind spending the money if it will cure my issue but don't want to spend the money if I still have the issue. Any other ideas?
Just a thought Keith but it sounds like your mixture has gone lean when was the last time the O2 sensor was changed?
Are you refering to part #1?
Lambda Monitor sensor L=580MM 1 11781742051 $261.07
I don't know, I've got a 2000 with a remus and it backfires. Before and after a new o2 sensor...
+1... Well, she used to anyway... *sniff*sniff* :crybaby:
My 99 with Remus and the chip does the same thing. Agree that it could be the O2 sensor.
My '03 does that too with the Remus pipe.
You have an exhaust leak somewhere, probably where the muffler slips on the intermediate pipe.
My '03, with remus complete exhaust system, sometimes backfires, sometimes not.
On its third o2 sensor with no change.............
I have both the chip & exhaust on my '01 and it's a matter of how rapid the decel is, air temp etc. some times I get backfire, mostly not although I'm more gentle on the throttle let off except for urgent situations.
O2 sensor will cause it to run richer when it fails, gas mileage will really go bad, I know on the K100's when the throttle was fully closed the fuel injection was shut off until RPMs went below 1500, may be different with motronic, a more open exhaust on anything will usually result in snapping and cracking, less back pressure
I have a 2000 with exhaust and chip and get some backfires as well. Much like BennyBob. Depends on the day, but I notice it normally happens when I downshift into a turn and hit high rpms with a big release of the throttle at the same time.
1 - 11 of 11 Posts
