Looking for a little help, have a 2005LT putting auxiliary lites under tip over wings and would like to use a autoswitch.Problem is I'm not sure where to hook up the trigger wire for the switch. I understand that the signal cancel switch is to be used but do you have to splice into the harness in the handel bar or is there a better location and what would the wire colour code be.Checking through the fourm I found mention of a brown wire white trace in large electric box?
