1 - 2 of 2 Posts
Hi All,
I have just recently found out that under the seat of my 2009 K1200LT there is a Autocom Active-7-Smart and a BTM 02A Bluetooth adapter. so the question I have is can I pair a Bluetooth device to the BTM 02A and play music through the Motorbike speakers?
Cheers
No. You can pair a device and listen to it through your headset on the Autocom unit. Even the factory intercoms would not allow you to play through the speakers. The only path to get music to the speakers is through the connector where the factory intercom connects but the audio quality is not good. I ran that for a while with a CanaKit amp to use as a pre-amp but gave up. Much better through the helmet speakers.
1 - 2 of 2 Posts
