You can, just hit the high beam trigger. It will turn off though in a short time when on automatic.meaning you cannot force the headlight on when riding if it is on automatic
True, but it doesn't stay on for long so is useless if you hit fog on a bright dayYou can, just hit the high beam trigger. It will turn off though in a short time when on automatic.
Yep, I have this enabled. just seems to need to be brighter to switch from low beam to driving leds than my 1250 GSA wasThe sensor is on the TFT on the bottom left - just below the indicator for keyless ride. My bike (UK model) switches from DRL LEDs to dipped headlight automatically but that can be changed in the settings (but not when you are riding, meaning you cannot force the headlight on when riding if it is on automatic).
It's not an omission. If you turn the auto off for the lights, it's works off the switch, just the same as the 1200 used to. We gained automatically switching lightsCrazy omission in my opinion.
.. but lost the ability to switch from DRL to headlight while riding. Not an improvement in my book. Unless I am missing some way of doing that?It's not an omission. If you turn the auto off for the lights, it's works off the switch, just the same as the 1200 used to. We gained automatically switching lights![]()
On my bike the DRL stays on even with headlight on. As I expected. The pre-'21 bikes' halo DRL also stay on, at least the few I observed Down Under. Road rules are different in the UK? I.e. DRLs must be off if headlights are on?but lost the ability to switch from DRL to headlight while riding.
Carda, where do you live? I'm going to guess USA?Does anyone know where the sensor is for this? Mine seems to stay in "low beam mode" even on overcast days. My TFT screen still has the protective film on it and I am wondering if this is impacting it? (doubtful).
He didn't say between low and high beam. He said between low beam and DRL, which, apparently, is 50% dimmer than low beam.I believe there is no automatic switch between low and high beam - only manual. At least I’ve never seen that and there is nothing about it in the manual. The TFT can automatically switch to dark mode when it detects low light
DRL's are on at 100% brightness during the day. When the headlight auto switches on at dusk the DRL's stay on but only at 50% brightness. When on, the headlight (both dipped and main beams) is always at 100%. This is the way it works across the EU. Bear in mind that the DRL's are are separate from the headlights, and the DRL's also function as parking lights, but again their brightness is reduced to 50%.Sixty: Seems like a very strange UK law that requires 50% dimming of headlights during the day. What's the point?
