That is where the harness for the CD changer in the saddle bag goes. Radio at the top, Changer at the bottom. I/K buss , ground, power. Then audio ground, left then right channel out from changer.
172937
172938
172936
He is looking to buy a replacement free plug, the one for the 'bike was cut off and discarded by a previous owner. It had been fitted with a Clarion 2 DIN radio and much butchery had taken place. OP is trying to restore it back to original.
Any suggestions for obtaining a plug or that section of loom to the rear?
Yes but now think the easiest way is but wires together withouth the plug's and tinning & cover plastic shrinking sock's
If you do that, you can't remove the stingray for service work. Worst case, get some car radio ISO to free end connectors and use those instead.
