I bought a supposedly BMW J&M new headset for my K1200LT over ebay but it does not produce any sound with my stock cord. I bought 2 other BMW 6 pins headsets last year and both work fine. So I am wondering if there is more than one 6pins layout for BMW headset or if this headset is defective .
All of the BMW pinouts are the same with the 6 pin arrangements. They are also the same as the J&M 6 pin CB/Intercom and all other J&M 6pins. Some of the cords have different style connectors, but you would not have been able to add the lower cord if that was the case.
Ron
That is what I thought so the headset must be defective. I contacted the ebay seller and she is saying that since the item was sealed and I opened it to test it she cannot take it back!!
She is saying that I should go to BMW and get it swapped!
Here are the pics of the BMW headset I bought as well as the pinout of my current stock connector. While my stock connector has 6 pins only the new headset connector has 8 holes. The headset came with a small cord that I also show in the pics this cord has 8 pins. I tried to connect my 6 pins cord directly to the new headset without using the additional cord but got no sound at all. If this is a genuine BMW headset (which seems to be the case as it says BMW Heaset # 82 00 0 419 582 on the box) then BMW has more than one pinout, one with 6 and one with 8 :confused: Can this headset work on my bike with some special 6 to 8 pins adaptor cord??
First pic shows my current cord pinout that connects to the headset
Second pic shows the 8 pinout on the new headset
Third pics shows both ends of the additional cord that came with the new headset
Thanks a lot of any suggestion
If I am reading your post properly, I think you need the cord from the link below. Take a look and see if this is the configuration for you.
http://www.sierra-mc.com/proddetail.asp?prod=JM-HC-ZJM
These cords are shorter in length than the actual BMW cords when used in the rider position.
Ron
Ron
Yes, that looks like the cord I need. You got it Ron. Big thanks :thumb:
Ron
It is shorter but is long enought to work. It's what I use.
The headset made by J&M is an 8 pin headset but the lower cord converts the 8 pins to 6 for use in J&M and BMW intercom systems.
