I have 1999 K1200lt. The bottom of the antenna is corroded. The spring and contact is shot.
Is there a short antenna or an alternative antenna that works?
Please post link where to buy it.
Thank you.
I bought a stubby antenna recently, and want to install it in place of the original tall mast on my K1200LT. How do I non-destructively remove the original mast to screw in the stubby??? It just doesn’t seem to want to budge.
If I understand your issue correctly, there is a plastic shroud at the base of the antenna that you need to turn anti-clockwise about a 1/4 turn. You can then lift the piece of plastic up to expose the connection point of the antenna. You will see where you can unscrew the base.
HTH
I order a Tune Trapper Hidden AM FM Antennas For Motorcycles yesterday.
He lives in Florida where I live, therefore it should be in day.s
Once again thank you.
Reactions: Munmi
Let me know how that goes.
My aerial broke and haven’t been able to find one (that doesn’t cost a small fortune).
