Hey Tony, might want to recheck that leak. Mine was leaking and the air was blowing it all over the place. Turned out to be the slider tube seal. Not saying you're wrong, I would just check to be sure.
Good tip, Dean. Cheers!deanwoolsey said:Hey Tony, might want to recheck that leak. Mine was leaking and the air was blowing it all over the place. Turned out to be the slider tube seal. Not saying you're wrong, I would just check to be sure.
Cheers, Paul.harrowbmw said:Hi people
I rebuilt mine last month when I was performing the bike's 80,000km service. Two new seals cost $1.62 each a few ml of oil. Perfect. Don't believe when BMW tells you they can't be rebuilt.
Cheers and kindest regards to all.
Paul Harrington
South Australia
Thanks, Andy. That is a better job of describing the process than I did in the opening post. I should have mentioned having my wife sit on the bike. Glad you caught it. :rotf:andy said:Checking for shot steering dampeners is actually quite easy: Put the bike on the center stand, have your wife sit on the back seat, so that the front is off the ground, then *QUICKLY* try to move the handle bars. You will feel and see and hear when the steering dampener kicks in. If the handlebars move more than 1" freely (you'll see what I mean) your steering dampener needs attention.
Fortunately, not very big at all. I have a spare kevlar vest you might borrow if your GF is a bit on the sensitive side.hd_ryder1964 said:How BIG of a wife will I need??? I'm in the market for one.... if I ask a girlfriend to do it she'll say I'm insinuating that she's fat!
Do you have a link or suggestion where to buy the seals? (in the USA preferably)e7navy1999 said:Thanks yall. I tacked the steering damper and it works amazingly well. Cost me $7 qt 10w fork fluid, $6 seals, and about 1hr labor. The most difficult parts was them dam BMW lock tight trox bolt. Lots of heat in the right places and a good snap-on impact driver. Gotta take off the fender and front wheel!!!!!
Yep, its doing nothing that I can see. With the tire off the ground and a movement left & right I dont feel anything.cws said:With the wheel off the deck, if you might the bars slowly left /right/left you shouldn't feel any real resistance.
If you move them violently left/right/left you should feel it stiffen up and harder to make the movements. If you don't feel any increased resistance, its likely the damper is shot, so needs repair or replace.
I just installed a Hyperpro Reactive damper on mine, and I can now feel the resistance increase in relation to the amount of left/right movement.. plus that's adjustable compared to the OEM thats either active or it isn't.. Hyperpro make a similar one they call constant dampening.
Have a look here for some graphs & info of how these things work...
Well, while posts #3, 6, and 9 doesn't answer if a kit's available, they do address your second question.00K1200LT said:Yep, its doing nothing that I can see. With the tire off the ground and a movement left & right I dont feel anything.
Is there a kit to rebuild it? or just buy a new one?![]()
Were you slamming it back and forward, or just moving the handle bars left/right....?00K1200LT said:Yep, its doing nothing that I can see. With the tire off the ground and a movement left & right I dont feel anything.
