Nothing against putting 4 more psi in the front than recommended by BMW (32), but do the same at the rear, and go to 40 psi.mcollect said:Running 36 front 38 rear. Tires are brand new.
Color? Hopz is going into troll mode? We all know color only affects handling when you are using synthetic oil, a Cee Bailey shield AND a lithium battery.hopz said:If memory serves... Tire pressure is 42psi Rear and 36 Front.
What color is the bike... it may make a difference.
The OM for the 2010RT does state to use 32/36 psi. That does seem a little low but is what's called out in the manual. I use more than that in mine. I think that the 36/42 is a better pressure in general depending on your weight and what load yo carry. I am also concerned that 32 psi in the front is a bit of a risk to the rim should I happen to hit a pot hole!hopz said:If memory serves... Tire pressure is 42psi Rear and 36 Front.
