Pretty cool, but the sparks seem to happen on every cycle, rather than every other cycle.meese said:
The reason that Harleys sound like they do is because they also spark on every revolution (also known as the overlap stroke). If you made a Harley only spark on the compression stroke it would sound like all of the other V-Twins.meese said:Some 4-stroke engines actually do spark on every revolution, but the "off" sparks have no effect..
Just about every vehicle I have had in the past few decades sparks on every stroke. Ignition firing on only power strokes pretty much went out when distributors did. If your vehicle (car, motorcycle, truck) does not have a distributor, then it likely fires on every stroke. The LT did, my BMW cars and Toyota Tundra truck do. I don't know about the Boxers, but assuming they are electronic ignition with no distributor, then they probably fire every stroke too.XMagnaRider said:Pretty cool, but the sparks seem to happen on every cycle, rather than every other cycle.
Is the boxer a two-stroke?![]()
You didn't read the top of the page, did you?XMagnaRider said:Pretty cool, but the sparks seem to happen on every cycle, rather than every other cycle.
