Very good!
Installed the DDM 5K deg low beam kit last night. The only down side to the install is that the sun started to come up before the install could be "fully tested"
. For a first time farkelization the process was pretty straight forward. BTW it is NOT a 1 hour process for a first time tupperware remover-er. Holy crap! There must be 1300 or 1400 screws holding all that plastic on! I had 5 screws left over but I'm not afraid because I'm going to order a high beam lamp and do it all over again! The original high beam lamp looks like a birthday candle compared to the new low beam! BTW I'm not a high beam flasher so the delay won't be a factor.
Any recommendations on the wattage for the high beam? 55W 85W? Kind of leaning toward the 85W. Why not? Just gotta make sure that I dim the high beams before I sterilize oncoming traffic!
Also tried to change the oil but failed. Got the old stuff out, put on a new crush washer, torqued the drain plug down and realized that my fancy new filter wrench wouldn'tt fit up into the hole. Nuts! Gotta git 'er done because I'm going on a 750 mile ride on Friday a.m. after I get off work.
Loren
Loren
