1 - 2 of 2 Posts
I have an 05 LT and want to disconnect the alarm unit.
Is it the same pins on this later model ?
jim
Just a little difference from the earlier alarm in how the turn signals are powered. You need to add the Green wire from pin 2 to the pin 10/pin 6 jumpered pair.
To get the bike running again you need to jumper the following pins on the 12 pin connector. Pin 3 (black/white/yellow) to pin 11 (black/yellow); this is the starter button signal to the starter relay. Then jumper pin 10 (green/violet, switched power) to pin 6 (blue/violet, engine electronics relay and also pin 2 (green, power to the flasher module).
Reactions: Patric
1 - 2 of 2 Posts
