Misplaced my Alarm FOB for my 2006 LT and need to replace. Do I need to order new or can I reprogram a used one?
Do I just use the process in the owner’s manual?You can sync up a used one but it will take a bit of time to do it.
Now I just need to find one! Thanks for the info.I would try that first and if that does not work or you no longer have a FOB to get it into the registration mode then just take the new (or used) FOB and cycle between the arm and disarm buttons several times to sync it up. This method may take several minutes of cycling to work.
65 75 2 337 407 | REMOTE CONTROL - 433 MHZ | 0.04 | 1 | $86.36 |
