While picking up oil for work at an oil distrubutor noticed he had cases stacked to the ceiling of 15W50 Aero Shell. Asked the sales person, he indicated it did not have an API rating and his opinion was that it would be unsuitable for use in a motorcycle engine. Tried to get him to commit to a reason but you know how sales people can be.
I don't plan to run it in my LT but now if I had a R, I would be very tempted to do so. Air cooled aircraft....air cooled motorcycle engines.....
I did get him to commit to a very good price on synthetic Shell Rotella T.
Maybe it will work in wings?
Bob
I wouldn't use in my bikes air cooled or otherwise because most piston engine aircraft produce their max horsepower (as well as a large percent (maybe 75%) of cruise power) at a relatively low RPMs (<3000). From what I've read about Motorcycle oils they need certain additives (like Zn & Mo) to provide anti-wear properties at high RPMs where the oil film gets too thin to protect metal to metal wear.
So I may be wrong but why take a chance?
Hi Curtis:
I get it, it's Harly oil!
Pocketta Pocketta Karl
Don't use any Aircraft oil in your LT! Actually, not even in a big aircooled V-Twin, which would seem to be a perfect match. They are not.
Aircraft engines are built a lot "looser", and burn considerable oil in normal operation. As much as we kid the Harley riders about their "old technology" engines, they are built quite tight. The aircraft oils are made with various levels of "Ashless-dispersant" capability, with much lower detergent levels than automotive oils. Aircraft engines run typically below 3000 RPM, and for long periods of constant 65-75% power output, and on takeoff quite a few minutes of 100% power, which means they have few "cooling" periods between high power runs. They are constantly burning oil, so have a lot less additives to reduce head/valve buildups.
Yes, go with the Rotella-T.
Prodigal Son
Piston (air-cooled) aircraft oil not only has a different wear additive package, but also contains somtimes little or no detergent/surfactant groups.
(large aside==
An interesting factor early on in the Mobil Av-1 tragedy involved the "cleaning effect" due to the automotive-like additive package of the original Mobil Av-1. This resulted in "softening & freeing for sudden ,massive and rapid re-introduction into circulation of sludge and other deposits causing many failures in up to that point "sound -running"
engines by plugging passages and galleys.
Mobil (to late to save the reputation of synthetics for most pilots) changed the additives. Actually by making the change they helped open the door for successful lawsuits by defacto admitting their 1st package of additives was an error.)
gunny said:
While picking up oil for work at an oil distributor noticed he had cases stacked to the ceiling of 15W50 Aero Shell. Asked the sales person, he indicated it did not have an API rating and his opinion was that it would be unsuitable for use in a motorcycle engine. Tried to get him to commit to a reason but you know how sales people can be.
When I went through A&P school back in the late 80's we were warned to never use aircraft oils in our automotive engines. The reason was that the automotive industry changes quickly with new innovations while the aircraft industry is very slow to change. It was explained that for an oil supplier to change the chemistry of an aircraft oil, it had to be tested and proven to be compatable with each and every type of aircraft engine that it was intended to be used in. That is a huge investment, and simply was not being done. We were warned that aircraft oils had basically remained unchanged since the 1940's. We were warned that aircraft engines still had cams that were extremely surface hardened to withstand the friction of the cam followers, while with the innovation in automotive oils had allowed for much softer cams. We were told that if we used aircraft oil in our vehicles it would "wipe out" the cam in short order.
Dont Use It
Aircraft oil although is great for Aircraft Piston Engines it is not for Auto's because of the loose tolerances in Air Cooled Engines.
Automobile oil is much more sophisticated than Aircraft with Long Chain Molecules Etc Etc.
Was the Oil Ashless Disperment? LOL
Good Luck
Stevea2980
