1 - 20 of 27 Posts
OK guys, I was active on this board (when it was an email digest) back when I had my '99 LT-I but I sold it (best I can recall I was tired of buying tires every 6K miles and wanted something a bit sportier). Since then, I had an R1100R, then a K1200RS and then back to an RT (which I still have) but now I'm finding as I age I'm not hitting those corners as fast as I used to, riding two-up on the RT is not as pleasant as it was on the K bike, and so I'm considering getting back into the LT world. I will probably keep the RT, at least for a while.
So, I'm not going to buy new, they're just too expensive. I have not yet ridden a 2005/2006 because I'm afraid I'll like it and buy one on the spot, but I understand that they ride much better, different front end geometry and maybe better weight distribution? From looking at the classifieds here and on IBMWR.org it seems that I can pick up a used 2005 for around 16-17K or get something as old as a 2002 for around 10-11K.
Other than the obvious things like warranty and the '05 improvements, what are your thoughts on the differences? I have seen a couple of things about rear drive failures, but I assume that it's the same or a similiar problem that BMW has had with failures on the RTs, and although it happens, it's not some common problem that I really need to worry about (I hope).
I'll probably go to the stealership this weekend and ride a 2006. I hope to be strong and resist the temptation to buy new.
Thanks all for your feedback and suggestions. FWIW, I absolutely despise the EVO linked brakes, but I don't see much alternative unless I buy something pre-2001.
Michael
I own an '02 and am VERY happy with the bike. FWIW, I also ride a sportbike and find that the two compliment each other very well. I wouldn't sell my '02 just to trade UP to the '05/'06 model. Not enough of a difference for the money, IMHO. BUT...if I was buying today, I would be VERY tempted to get an '05 with low miles. I just wish they didn't come with that hydraulic centerstand. That's the one new "feature" that I really would like to see turned into an OPTION before I buy my next new LT.
Trust me...the linked brakes are more intuitive than you're giving them credit for. Stay off the front lever when you're going slow. But other than that, you'll find that they are very "smart". They aren't as linked as you may think they are. Don't get me wrong...I don't want linked brakes on my Ninja. But I have learned to LOVE them on my LT. Don't let this be a deciding factor for you. JMTC
I don't know where you are but at the local dealer in Wichita there is a left over 05. You could possibly find some other places and get a good deal on the new 05 instead of going used.
I have not ridden the 05 but if they are better than my 99 they are excellent.
The bigest problem I've heard of with the 05 is the centerstand having some problems.
And some have a frontend shake.
The '05s have a "frontend shake"?! This is the first I've heard of that. I hope you're not referring to the mystery frontend wobble that all that years have experienced from time to time. I'm fairly convinced that "the wobble" is caused by worn and/or improperly balanced tires. 'Twas the case on my '02 a couple of times. No big deal though...
Mess-13,
I should of called it wobble I suppose. I've read more about '05 and not being able to take your hands off the bars than other years. Remember they did change the geometry of the '05. Some have reported that reballance / new tire didn't fix. Who knows for sure.
I own an '03 and I am very pleased with it. It and the '04 with low mileage may be a good balance with the linked brakes, new rear end bearing config, multi disc cd, but no updated centerstand and the original geometry.
Your short tire life was probably caused by following BMWs recommendation for tire pressure. It should be 42 in the front and 48 in the rear. They gave me a new tire in the front because the recommendation was wrong in the manual...
His short tire life may have also been caused by the Bridestone Exedra tire. They no longer manufacture that tire due to it's short lifespan. Very sticky, but you were lucky to get 6 or 8K out of it. I bought a NOS one off eBay last summer. I got it real cheap, so I didn't care too much. I don't think I got much more than 6K out of mine. Hopefully, that was the last one left on the planet.
Power Center Stand
For those of you that just hate your power center stand, I'll be happy to swap it for the manual one on my 02.
Les
Did the same thing
Hi Michael
I had the same questions when I was searching for my LT. Do I buy it new? do I buy it used?. I kept asking for test drives on the 05's at the dealer, and my dad had an 02 so I kept asking him to go out on rides. Could never decide.
Money was the big deciding factor and I ended up with an 02 LTC with 5800 miles on it (well 9000 now) that I picked up for 12K. Well since than my old man has upgraded to a new 05 (he liked the center stand, the dash and he seems to think the geometry makes the bike feel lighter) althought it really is not.
Me after buying my 02 and putting nearly 4K on it, and occasionaly riding my dad's 05. I would NOT trade my 02 and the price I paid for it for nothing. I had 17K to spend, spent 12K and kept the other 5 on the bank.
Just my two cents.
I had an 01 LT and I thought the power center stand was a silly idea, now have an 05 and I love the power center stand and use it almost always. It also really helps about smoking at start up itstead of using side stand. Just my $.02 worth. Through the years I've learned the hard way to never say never. :)
Leon
05 Blue LT.
I bought a used bike.........
......from Chicago BMW. My avitar picture is me taking off from Chicago in January for Toronto, Canada. Yep, cold. Anyway, while you may have already bought something, here's what I learned.
1. Buy something still within the warranty period.
2. Buy used, the $$ you save are worth it, if #1 applies.
3. Buy in the winter, when the used bikes are just sitting there. Best prices.
4. The new LED dash - kinda neat but if you do any cold weather riding LED's don't work as well and harder to see at night. Personally I like the needles myself. The changes to the new bike are ok but you've gotta look at the $$ you save and determine if it's worth it for you.
5. Buy from a dealer. I know, I know........BUT, in the worst case scenario you have some recourse if the engine falls out or whatever. You get the idea.
Have fun.
I owned a 99 LT for over 50k and currently have an 05 with 44k and there is no doubt, in my mind, that the 05/06 is much more bike for the $$$. The center stand was an issue with the early 05's and I did have this happen but as you would expect it was covered under warranty. A used 05 would be your best deal as the 06's have went up in price. RIDE SAFE
Having just gone through this exact exercise here is what I found. I was looking for a clean low mileage '02 or '03 Custom Model. I ultimately found a deal on a pristine flawless '05 with 11K miles on it for almost what some '03's were asking. After searching for a few months here is what I would suggest. The best vintage seems to be the 2003's for these reasons ...... they are relatively free of the rear drive issues, they have the tape player replaced with single CD which allows you to remove the 6 CD changer and still have a CD (this allows more packing space in the right bag) many are still under factory warranty which allow easy purchase of extended warranty if you like, and many have low miles. If you look hard you can find a nice '03 for $11,500 to $12,500. Also, if you are like me at 6'3" tall the '03 models also had the better seat IMHO. I love my '05 but they sure messed up the seat for anyone over 6' tall. So I am now thinking of a aftermarket seat for my '05. But if you can find a good deal on an '05 you get more HP, power center stand (very nice feature) , better handling and factory warranty for sure. If you are inseam challenged then the '05 may really be the way to go. For me .... I think the ideal bike is a 2003 although I love my '05. I hope this helps.
Just keep looking ... every day .... check ALL classifieds and dealers. Look hard and there are some great deals out there.
I had an '99 LT, and jumped between it and my Harley. In '05, I bought a new '05 demo with 800 miles from Iron Horse in AZ. I paid $16,600 for it, which I considered an excellent price. In the Bay Area of CA, I couldn't find a deal on an '05 to save my life, and there were no demos available.
My wife and I LOVE the power center stand. With achy knees and a bad lower back, it makes putting the bike on the centerstand child's play--ever try putting a fully loaded LT on the centerstand, with a bad back? Good luck! Also, getting off the bike is easier when on the centerstand, IMHO.
I do prefer the low speed handling, parking lot maneuvers, on my '05 as opposed to my '99; and the bike does feel more flickable in the tight corners. The linked braking system does not hamper low speed braking in tight maneuvers, if you're NOT heavy handed (footed).
I love my '05, and it'll probably be the last motorcycle I buy--I'm not getting any younger!
New K1200LT
I just traded an '02 R1150RT for a '99 K1200LT six months ago. We are not long mileage riders but we had 36K miles in 2.5 years in the western US on the R1150RT.We travel mostly two up and I did not go for the K1200LT sooner because of the price. But with hindsight being 20/20 I should have done it in '02, whatever the price. The rides would have been ooooo so much better. If the new are any better than the '99, and I think mine is wonderful, go for it. I go for the curves just as hard as I did or more than the RT. I may have been afraid of dragging a head and end up with higher insurance premiums. I am 6'3" and 245lbs. so the RT felt a bit cramped but the K is comfortable and we can go all day again without being exhausted. The cruise control on straight roads and interstates. The heated seats are very welcome on 20 degree mornings. The only problem with a wobbly front end was a tire that went bad and worped. New tires no problems. If you think it is too heavy and may be apt to fall over. Well I witnessed a 125 lb. woman pick one up at Foothills BMW, in Lakewood, CO. If have used it, the bumpers on the side are there for a reason. Learn the technique to pick it up and enjoy.
Life is too short to compromise on your toys.
Michael, as you said.......................!
Discussion Starter #19
Heh, heh, good point!
Thanks all for the feedback and suggestions! The search continues...
Michael
1 - 20 of 27 Posts
