Throttle action is very sticky. Saw elsewhere on the forum advice to first try lubing the cables from the top end. It was described as a simple job.
I took out the Clymer model and followed the simple instruction: remove one screw, remove bottom part of throttle cover on handlebar, exposing cables and lube.
The Clymer portrayed the throttle cover assembly as two pieces: the cover itself, and then a curved plastic piece through which the cables were routed and to which the cable tubes were connected.
But when I started to do this, (l) I couldn't get the cover bottom to separate and (2) it sure looks like the plastic piece through which the cables are routed is part of the cover bottom.
I couldn't see any seam or point of separation (although my old eyes are getting worse and I couldn't get the best angle for the examination).
I didn't want to force anything, so I restored the screw and now ask for advice. Thanks.
Larry Johnson
El Paso TX
Larry Johnson
El Paso TX
