2000 K 1200LT previous owner had removed the ABS warning light bulbs as they indicated a fault, I have not been able to find the problem, today I removed the ABS valve and took it apart--major job-- WARNING-- the valve has 4 big high tension springs inside and can seriously hurt you when the last of the bolts are removed and the coil springs expand, more like an explosion.
Question---Can the ABS be removed and the brakes lines connected directly from Master cylinders to calipers? The bike only had 1911 miles on it when I bought it in 2005 and I do not think the fluid had ever been changed, the inside of the abs valve had some corrosion but from what I saw not enough to cause failure.
Sonny
Sonny
