Hi all, really need help,i changed the front and rear pads on my 04 lt today.When I started it up the warning triagle appeared and when I applied the rear brakes,it sounded like the servo was stuck, anyone any suggestions?
Normally replacing brake pads shoud not cause a problem. Just curious if you have been keepng up with the annual brake system wheel circuit flushes? If not, given the high moisture in your area, that could be the cause of the problem.
When you say the servo sounds stuck does that mean it continues to run? If so it could be a brake light switch on the pedal is not releasing. The servo responds to both that switch and pressure to trigger it to operate. I would check to make sure you can hear it "click " on and off as you push the pedal (key off) with your hand.
A forum community dedicated to BMW Luxury Touring motorcycle owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, reviews, and more!
