1 - 2 of 2 Posts
I replaced my battery and the ABS light is still on..Does it need to be reset by the dealer?
The sensor is clean and the brake fluid is full.
Thanks in advance
Nope. The Integral ABS will self clear the warnings when you fix the fault. So what ever caused it is still there. Low battery usually triggers a fault on the ABS II units I have not seen that on the I ABS. Is it just the ABS light that is on steady? If so then there is an internal fault in the ABS unit. A dealer or some one with a GS-911 unit can pull the codes and tell what it is. But it does not look good.
1 - 2 of 2 Posts
