I'm a long way from home and the ABS light is flashing. I need to get home quickly. The brakes seem to be fine, can I ride it home safely without hurting anything. I checked the fluid and looked for something around the sensor (clean).
Is most the fluid level in the secondary brake circle. Will go away if you change your rear brake pads. Be careful but I think you can ride home without any trouble and without damaging anything.
Manfred
Enjoy The Ride
K1300GT K1200LT
The year of your bike 2003 has brake fluid monitor level switches. Most likely it is just a tick low on fluid & should be fine to ride home.
mwnahas said:
brakes will be still power assisted, but just won't have ABS available.
What Mike says, you should be good to ride home.
