Just replaced the F tire on the '00 K12LT; shortly thereafter, got the dreaded wig-wag ABS lights. Checked fluid levels, sensor gaps, etc; all in order.
I did go up one size, from a 120/70 to the 130/70 (Avon, had good svc w/them) has same speed rating (V) but higher weight rating. Only marginally wider, but also slightly larger in circumference. Seems to be around 2-2.25".
I'm wondering if this difference in circumference would cause an ABS fault.
Anybody???.
Anybody???.
