did winter service a while back finaly got nice enought to ride her. when i took her out for a ride i get a slight antifreeze odor when i take off from a red light. seems to be from the left side. dose not seem to be leaking.
other than not getting the cap on correctly when i changed antifreeze.(nasty piece of buissness with tank on) any other suggestions
i did spill some but have ran the bike in the shed a bit . first time fan cycled it steamed out a while. some may have got on the engine but i have run the bike several times.residual should be gone i think. i am gonn try to take the cap off later today for inspection.level seems normal
What Michael said.
And, I spilled some and the engine smoked and smelled when I first fired it up. After it burned off everything was OK. I too, did not remove the tank, that was why I spilled some. :eek:
yes my fuel tank was on it was very difficult to r&r the cap. that is what is making me think the cap may not be on correctly
Bob, you may just have a case of expansion and overflow from the expansion tank. I have had similar smells in warm weather after doing a coolant flush and fill.
bobst2 said:
just checked level in sight glass. it is a little below max line when cold
