While I'm waiting for the BMW Bluetooth systems to arrive, I went to pair my Scala Cardo G4 headset to my bike. The BMW pairing instructions say don't allow any Bluetooth device to be on within range of the bike -- they are not kidding.
I did something that others may inadvertantly do: In order to pair with the bike, you have to turn the ignition on. If you have a Nav IV installed, it comes on when you turn on the ignition! Duh. Once I figured this out and removed/turned off the Nav IV, my G4 paired almost immediately.
HTH someone!
I paired my G4 no problem with the GPS Nav IV turned on. It is already connected to my G4. The only problem when I paired the G4 to the bike there was no sound on the G4.
Garry
Garry
Garry, did you get the no sound problem sorted? My G4 paired ok, and at first I did not have sound. If I recall correctly, after I turned the bike off and back on, turned on the radio, and turned up the volume, I had sound in the headset.
I haven't tried that, did you turn up the volume using the multi-controller? When I tried to use the volume on the Nav IV and it said to use the headset volume.
Garry
Trying to remember (CRS strikes again!) I *believe * had to turn up the radio volume with the multicontroller wheel -- I don't know whether it was because the system turned volume down when shifting from bike speakers to Bluetooth, or (more likely) in my radio On button pushes, I inadvertantly muted the radio.
