1 - 16 of 16 Posts
I have an opportunity to buy a 78 R100 /7 with 10,000 actual miles! It is an estate sale, but has been cleaned up and runs great. My question is, would you consider this a suitable bike to drive to Cabo or across the US? Even with the low miles, how would this compare to a modern bike for reliability? Getting stranded in Baja would not be much fun. Thoughts?
The best thing about the old air heads is that they go on forever if you just keep the fluids changed. The only thing I might suggest is that you carry a spare set of points & carb diaphrams. The 77 model I had was probably the most reliable BMW I have owned & the least likely to leave me stranded. No rear drive failuers to worry about. You do need to lube the drive splines in the rear drive when you change tires, and lube the transmission input shaft splines every 50K or so. It is probably the best bike around to take to mexico since it will run on almost any gas when necessary. Todays gas is hard on the carb. diaphrams so if the bike starts running where it tops out about 80 they probably need replacing. Be sure all the fluids are fresh especially the brake fluid since it has been setting so long. If you decide you do not want it let me know, I might come and get it.
Good Luck.
BMW Guru
I would think it would be as reliable once you get it sorted out. I would get on one of the air head forums and find out all the little upgrades they to before riding it too far from home. I'm sure there's a modern replacement for those points...
Reactions: Patric
I miss my 78 R80. I could change the rear main seal in the driveway on a Saturday afternoon and still have time for a good ride.
Reactions: Patric
No replacement available for the "bean can" setup - which was only used in a couple of years.
The good news is that once properly rebuilt and serviced those "points in a can" can work just fine and for a LOT of miles. Mine work flawlessly, and as long as they get a quick "sphritz" of light oil once a year they can take a lickin' and keep on tickin'. :D
Unless the OP has some serious mechanical expertise a rebuild of them is best left to an expert - which is damned hard to find these days. Most of the Airhead electrical gurus for hire won't touch 'em since it is a ton of work to get them up to spec after sitting for so long.
Lots o' beans in there!
Had two of them. with over 100K on each and they just just keep on ticking.
If you don't buy it let me know.
Do all the recommended maintenance and I'd say that you've got a bike that is more reliable than the new BMW's rolling off the showroom floor. Do not ask me how I know.
Yes, reliable.
If you do a few things.
Having done frame-up rebuilts of a few 70's Airheads I can suggest a few things to do.
Do a complete service including new points, condenser, sparkplugs. Put the old parts in the toolkit under the seat. New battery?
In addition to the above, when the tank is off open the headlight bucket to get access to all the electrical connections in there. "Refresh" every connection by pulling off the spade connector, give the terminals a spray of electrical contact solvent, and remove and replace the connectors a couple of times. Do this in the headlight bucket and under the tank at the starter relay and voltage regulator. This will remove some of the oxide that increases resistance at the connections.
Yes, these old Airheads are pretty bulletproof. I like /6s better than /7s but they're all good. And yes, much less likely to give you trouble on the road than a modern BMW. AND if you understand the bike's systems you are MUCH more likely to fix a problem by the side of the road with the bike's tool kit than you are a modern BMW. These old Airheads are the bikes that gave BMW a reputation for a low maintenance, reliable, long distance tourer. Those are the "Legendary Motorcycles of Germany". Note that BMW doesn't use that catch phrase anymore. :histerica
That's an excellent idea and one that I didn't do. On the list, thanks!
I'm a huge fan on Nutrol cleaner and lube - it has solved many an electrical gremlin.
Don't know if you pulled the trigger yet on the '78. My icon photo is the 1980 RT which was kept and ridden for 22 years=206,000 miles. Only problem I ever had was the points would get pitted quite often--easy fix. The front lower engine cover cracked up the middle so it was replaced, tach quit working-likewise replaced. Normal wear and tear stuff after that. Routine factory recommended maintenance. Oh, I forgot--rebuilt the Bings one time.
Mine's rock solid. Ride it anywhere with confidence.
Great looking bike, BMWHD!
To this day I am still looking for that "pristine" RS airhead. There used to be a guy in Arizona who restored and sold them, I should have jumped at the chance back then. I wonder if he is still doing it?
Dave
I have over 300K miles on airheads since my first one in 1969 from /2 to /7. My R75/7 is pushing 155K miles, 60K since I've owned it. My 1960 R69S sits with 300K plus miles and is ridden regularly for 1000 mile jaunts. My wife and I completed a 3200 ride on the R75/7 last summer, taking it in lieu of the LT which I'm never quite sure is not going to choke somewhere far form home. No airhead has ever left me stranded longer than a problem I could resolve in few hours with the factory tool kit and spares carried in ditty bag. l can't say that for my LT, though my 87 K100 was probably as good a BMW as they ever made. Aforementioned suggestions by other riders are excellent. Service and maintenance are the keys to longevity but unlike modern Beemers, it can be accomplished with simple tools and a simple mind. I enjoy the comfort, handling and performance of my LT but for pure riding reliability, give me an airhead any day.
Points in can started with 1979 models, so this one won't have that. There are likely still electronic ignition conversions available.
1978 R100/7 has 9.0 compression and BMW specifies premium fuel. If subsequently dual-plugged, regular should work.
Everything rubber in the brake system should be renewed, i.e. master cylinder rebuilt, caliper rebuilt, new brake line. More than likely the rubber pushrod tube seals will leak and it will probably immediately need new carb diaphragms and o-rings.
1 - 16 of 16 Posts
