1 - 1 of 1 Posts
Not quite ready to deep-six the SPIII/Nav for awhile so here's the 376C (same as 276C) using the furnished marine mount on a RAM mount on the BMR shelf. The RAM mount is the one that the tag end has a circular disk with lots of holes (6 I believe). If you look at the marine mount and remove the knurled thumb screw, you can see that the base aligns with the RAM mount perfectly, and is a quick disconnect either from the RAM mount OR using the thumb screw.
If the above is self-evident/obvious I please accept my apologies.
Any questions, PM me.
The unit, while not in the picture (was in car) fits quite nicely and while looking a bit over the top with 2 GPS's, well, reduncancy, it can work!
Power will eventually come from te maplight but am wondering how long the lithium battery works. Audio will feed into VOICE II and the puck/XM antenna will mount just to the left of the RAM/marine mount.
1 - 1 of 1 Posts
