Took my bike to dealer today for annual maintenance and to address some warranty issues. Current mileage is 33237 km (~20,700 miles)
1. Had the brake wheel circuits flushed and a bleed test as per annual requirement. Fluid was very clean. A copy of the bleed test is attached for info. This was the only work I had the dealer perform. I will do all the other annual checks. Cost was $233.86 Can.
Note: BMW has issued a Bulletin dated Nov 2007 that specifies that the ABS Control Circuits can be flushed every 4 years - as opposed to every 2 years on the Maintenance Schedule.
The following work was all done under warranty:
2. I had 2 of the chrome strips (p/n 51-13-7-699-569 and 571) replaced on the outlet from the cooling port. The chrome had started to come unglued as shown in the attached photo.
3. The exhaust mounting bracket (p/n 18-21-7-656-032) had fractured and was replaced . See photo.
4. I noticed some looseness on my rear wheel this summer - but did not appear the be the rear drive. When I showed the dealer - they said it was the paralever needle bearings. The bearings were replaced (I thought these would not be covered by warranty but they were!!).The bearing p/n was 33-17-2-311-091.
