Well, I am about 1/3 done on my first 24K maintenance. Here are a few observations in no particular order:
1. Having taken off the tupperware a few times now helped a lot. I had the bike pretty well stripped in less than 1.5 hours.
2. Bleeding the brakes took me nearly 6 hours this first time. This included making up the spacer blocks and so forth and just being very deliberate not having done it before. I think I can probably do the job in a couple of hours next time.
3. The air filter was easy to replace once the tank is off. However, the filter that came out looked like new after 5 years and 27,000 miles. I will definitely not be in a big hurry to change the filter next time, although probably have to pull the tank at 48,000 for other reasons, but maybe not if I can do the valve check and coolant with the tank in place.
4. Have to get a strap wrench to get the fuel pump assembly out so I can change the fuel filter. I am guessing that this job can be done much less frequently than 24K miles. My cars go 100K on their fuel filters with no problem and they flow a lot more fuel in those miles than does the LT. I can't believe BMW has the fuel pump come out the bottom of the tank. Most cars I have seem have it come out the top and this would have greatly eased servicing on the LT. I sure hope I can find a strap wrench that will loosen the plastic collar.
5. The Clymer manual talks about greasing the side stand bushing with a grease gun, but I haven't seen a zerk fitting. Is there one there that is just hard to see? Or does the stand need to be removed to properly grease the bushing? It looks like removing those springs and replacing them could be a real pain!
6. Same for the centerstand, is there a grease fitting? Or is disassembly required?
Now on to the coolant change, valve check, and spark plugs. I had not planned to remove the airbox, but the bike has had an off-idle hesitation for the last year that I have been unable to find. I thought it was the canister, but I disconnected that last year to no avail. My leading theory is the crappy ethanol poisoned gas we have, but I am wondering if I have a vacuum leak somewhere. However, the idle isn't all that unstable so I am not sure it is a vacuum leak. Maybe O2 or some other sensor, but don't yet have a GS-911 yet to check.
