2022 Triple Black R1250rt. Previously 2009rt, 2011K1600, 2017RT, 2019RT
I am using a Samsung S9 dedicated phone that I leave on the bike. It does not have any covers obstructing between the phone and the charging pad.
I have noticed that unless my phone is pre fully charged, on a few hours ride the phone will use more power than it will charge whilst in the pocket.
I typically have the map connectivity and play music.
If it is fully charged then it never gets to "red mode" even after an 8 hour day.
My latest example was a 4 hour ride today where the phone was at about 50% when I started. Within 3 hours the charge was down to red on the screen which when checked showed 24% on the phone. The light in the pocket also changed from green to amber after about 30 seconds when I put it back in.
I then moved the phone to a dedicated direct to battery port in my topbox. Was up to 60% within 30 minutes. Also had full connectivity to not sure it has to be in the front pocket to function properly.
Am I assuming correctly that the wireless charging is not a "full" charger or is there something else possibly wrong?
