1 - 20 of 114 Posts
· Premium Member
2021 RT
New to the forum but a long time BMW/Ducati owner. Just picked up my option 719 RT and had the dealer mount my Nav VI above the TFT. Using the cradle it works well, wonderwheel obviously does not.
Having the music replay issues with my iPhone others have reported. Hope that gets resolved, otherwise love the bike.
174330
174331
174332
174333
· Premium Member
Welcome and congratulations! I am fairly sure that you will love the RT!
Reactions: Geoff c
· Premium Member
Could you post the pic of your mount?
I am very curious as to me that is a great addition to the bike.
I am sure you can use the TFT mounts and a backer plate just curious what you did?
· Premium Member
I think half of the forum really wants to see how this nav is mounted and are patiently waiting for pictures LOL. I know I would like to see this as I'm very curious about mounting my Zumo XT there.
Well if it was me, that TFT is attached to something bracket wise behind the headlight. I would pull the headlight and see. But I would have a cradle and some aluminum flat stock before I started. If I could mount a plate I could mount the cradle. Maybe pull the speaker cover and look around first?
Reactions: Geoff c
· Premium Member
2021 RT
Discussion Starter · #13 ·
I spoke to my dealer and the mount is made in Germany and used on Police RTs for mounting radar. They had to rotate the radio antenna 180 degrees and made a minor dash modification to install the bracket. The bottom edge of the Navigator rests right against the top edge of the dash. I waiting to get the exact part number but apparently the bracket is designed for the bike.
· Registered
Can you post a picture?
· Registered
2021 BMW R1250RT
Oh that looks good. That bracket is made right for it and my Zumo XT would bolt right up to that bolt pattern, but it's a little taller then that Nav IV so I might have to fiddle with it. If you could get the part# that would be great. I need call the dealer and see what they can find out, but after seeing this I bet any 90° piece of medal can be mounted there unless the bottom piece is rolled semi-circular.
Thank you kind sir for the pictures!
1 - 20 of 114 Posts
