After doing a valve adjustment and TB synch, I checked the fault codes with my GS911 and got "10048 Oil Level Switch Malfunction" . I did not check fault codes prior to starting the work, so I can't tell if it was there previously. I do not seem to have any warning lights or indicators on the dash that indicate an oil fault of any type - the Oil "---" is there, but doesn't change to the "check" after warmup and ride. No other lights are on.
I checked the Bob's parts fiche, and the switch appears to be a float switch with a single wire pigtail on it. Unfortunately, it's not shown on the parts diagrams in any relationship to the rest of the engine. Just sits out there by itself on the engine block page.
Can anyone tell me where on the engine the switch/sensor is? I believe I have found it on the lower right side of the block, but I would like some confirmation. I have the skills to change it - I just need to confirm the location.
Thanks in advance for your assistance.
