1 - 3 of 3 Posts
Specifically where is it and what style of connectors are used. I have'nt found out through looking at the audio manual. The controls are infront of the rider and the CD player is in the small compartment in front of the rider, I don't know where the main radio is. Thank you
its the 3.5 mm plug on the right hand side, plug your source into that and then select from the dash board AUX you will now have music or what ever
If you have the intercom unit its controls will be directly above the single CD unit (which is also the main radio). There will be that 3.5 mm aux input recepticle there as well. If there is nothing but a blank plate above the CD unit you will need to add a cable for an AUX input.
1 - 3 of 3 Posts
