Recently the low beam HID failed on my 2005LT. The igniter had failed when bench tested. The replacement unit did not start when installed. Turns out there is no power to the low beam circuit (green w/ blue tracer) as the left and right side markers do not light either. I have power thru the #5 fuse and the tail light is on.
High beam works fine and drops out when starting. Strangely the tail light does not go out when cranking.
Any ideas on where to start looking?
Thinking that I may have to pull the tank and have a look in the wiring box.
