I dread writing this post given all the other posts and videos on this topic. I've replaced all my lines and have the integral ABS on my 03, with the tall ports on the side, facing the rear. However, the fact is I'm stuck and frustrated need to confirm the correct sequence of what to do next.
I successfully pushed fluid from the tall ports into the reservoirs and from the calipers. It's the sequence of what to do next that I'm in need of, presuming the next step is to bleed the system. For the front, 1,2,3 and back to 1?
PICTURE 1: Do I have the ports correctly numbered for the front system? (I'm presuming the same for the rear system on the other side.)
PICTURE 2: Even with a bent 7mm wrench, what's the trick for getting it in the recessed area and getting it to turn?
What's the best I.D. size tubing for this job? Some pictures look like 3/16" is being used.
