I apologize if there is already a thread on this, but I could not locate it. Can anyone tell me how much of the 2001 LT is compatible with the 2005? I have a 2005 and found a 2001 that I was contemplating purchasing as a parts bike. I know that the dash is not the same, but is there much else that was altered? Thanks in advance.
In addtion to all previous replies, you need to be careful on swapping any major engine components as these parts are also different and will have major effects if combo is wrong:
(1) Engine pistons (higher compression ratio in 2005-2009)
(2) Intake and Exhaust camshafts
(3) Throttle-bodies assy (larger diameter in 2005-2009)
(4) Motronic EFI unit (ECU tuned for above changes in engine)
OF course, because of many other changes (dash , ABS modulator, EHCS...), the main wiring harness is very different in both generations.
