Hello. I'm new to the forum and as of last month, new to the family of K1200LT owners. I bought a very nice 2000 model with less than 40k miles. I love it. I was doing some brake repair on the rear and found that my master cylinder was going out. I assumed (incorrectly) that I could buy a rebuild kit. Ha! So . . . . . . has anyone here had good luck finding a rebuild kit? Or maybe a kit with compatible seals? The bore is 14mm.
Thanks for any help or suggestions.
I have a 1999 and mine went out last year and I just picked up one on ebay. There are a plenty of them out there and they are rather inexpensive. Perhaps you can pick up one until you can locate the seals for your original rear master cylinder.
Re: 2000 LT Rear Master Cylinder Kit?
Thank you for your suggestion. I'll give that a look.
Discussion Starter #4 (Edited)
Solution Found:
Thank you dvpadgett for your suggestion to search online for a good used Master Cylinder. I went to eBay and found several for $35.00 and less. I purchased the one that looked the cleanest thinking it probably came from a well maintained or low mileage bike. The price was $15.99 plus $10.00 shipping. It arrived in 3 days and looked great. I disassemble and flushed with new fluid. I then did a bench bleed and carefully installed it on the bike with the Master Cylinder still full of fluid. Once on the bike I did a full rear brake bleed. It works GREAT. I good full and firm pedal. Like new. Thanks again to dvpadgett for your suggestion to search used.
