Looking for advice and assistance from the collected wisdom of the board.
After several years of less-than-intense usage, my LT has been racking up miles again, and in the stunning heat that has been thrown at the MidAtlantic states. I'd been doing 100% virtual work for the last 12 years, and thanks to an unplanned and non-optional 'retirement' (long story), I've been doing a great deal of riding to try and find a new job.
Apparently, the bike didn't like it. :-(
After returning from Carlisle, PA on Friday I found oil under the head side of the bike. After burping the tupperware, I found oil at both lower corners of the valve cover, and on further inspection, fouled throttlebodies indicating the steekin' crank breather has also taken a dump. Perfect timing, of course - no job, no income, and this bike is my primary transporation for rebooting the whole micro economy.
So I have a few questions.
Will just putting the fairings back on and whisteling dixie -- i.e just letting it leak -- hurt anything other than my pride of ownership?
Second, IF my terminal anal retentive qualities won't permit this, help me make sure i understand the job and the required parts, as I cetrtainly won't be able to pay someone else to do this.
The Valve cover seems pretty straightforward - I'll need the gasket, the rubber bushings that the cover bolts run through and some black hi temp selant for the half moons and the joint at the timing cover. Clean up, replace and let cure for a day.
The breather, on the other hand, looks to be a major pain. Looking at the parts diagrams isn't really instructive - its shows an assembly labelled 'distribution hose' - PN 11151465009 that appears to include both halves of the breather and all of the clamps etc -- am I reading this right or do i need to order clamps etc in addition?
Does anyone have any pointers on what to use to clean up everthing before disassembling -- brake cleaner and rags? -- and any gotcha's about how to get everything back together properly? From other posts it looks like losening the entire FI assembly from the head, sliding it out of the rubber sleeves and then unclamping, removing and replacing the breather, then reassembling is the what of it.
Is is possible to do this without pulling the front suspension? Sombody mentioned using medical forceps or really long nosse pliers is a way of working around the 'my steenking fingers won't fit in there' problem.
I apprecaiate any and all assistance to help me fully understand this job before hitting the point of no return. And if any Baltimore/Washington area guys have done this before, and think this is their idea of a good time, I may not have a paycheck, but the mancave fridge is still full of the good stuff. ;-)
Thanx
Thanx
