A kind gent on this board, kinch, sent me a "dead" ABS unit. There was no information regarding what kind of failure occurred.
I am curious what different fault reports might be reported by the MoDiTec computer when an ABS unit is bad. Does it just report "bad ABS" or is there more info than that?
Pics attached of the unit I have disassembled.
I suspect that this unit may have had a failure of the electronic box because I couldn't find anything wrong in the mechanical/hydraulic section.
There is a lot of pent up spring compression and disassembly is a bit of a puzzle until the sequence is figured out and the needed tools fabricated. I had to modify some fasteners to remove them and had to fabricate a couple special tools to get the unit disassembled but I believe that these units could be rebuilt. I did not find any sealed ports making passages inaccessible. I kind of doubt it would be worth the effort however. If someone were to have a collection of bad units that they could pull parts from and a way to bench test the units it might then make sense. Swapping out a bad circuit board for a good one would be an easy fix if there is a way to tell if it is the circuit board and not the mechanical unit that is the problem.
I have a pretty good understanding of how the unit works, having studied it while taking it apart. I bench tested the main motor and main motor relay, both okay. I have no way to test the circuit board other than to reassemble the unit and install it on my bike and see what happens, I'm not willing to do that. There are a couple of electrically activated clutches that are controlled by the ABS circuitry that I didn't test. I could apply a variable voltage source and increase up to 12v just to check them but at this time I don't see the point. I'm not planning on trying to put this unit back into service at this time. There are also two field effect sensors that tell the ABS circuitry what the status of the pistons is, that would be a pretty easy check for someone with a working knowledge of electronics.
I do think that it makes sense to activate the ABS unit on your bike periodically by locking up the brakes and making the ABS unit function. I believe that this will move fluid through the unit in a way that does not normally occur. Doing this ensures that fresh fluid from brake fluid changes travels through parts of the ABS unit that it would not otherwise. I can see how the pistons could become gummed up and not function properly.
This is posted for general information and was done for my own entertainment. The practical solution for someone with a bad ABS unit is probably to source a known good one from a recycler or bite the bullet and get one from BMW.
