I'm sure some of your have experience with these two tasks.
1) I have a fork seal to replace. I plan on just dropping the slider off the leaking side...sliding the lower slider off the upper fork. Do you know if it's possible to slide the lower fork off the upper fork without having to lift the bike for ground clearance? If so, do you think I could use an engine hoist? or any better idea you might have.
2) I've seen pics where folks have pulled the canister and all vacuum hoses off the throttle bodies replacing them with vacuum plugs. Once you do that and disconnect that electrical connector, what do you do with that electrical connector? Let it hang?
Thanks for the help...I hope it benefits others as well. I'm getting closer to getting BaDsalt back on the road and the excitement is welling up.
Tom
Tom
